Thread: 7g stut tower bars
Showing results 41 to 60 of 61
  1. #41
    Experienced TGC Member Bezzle's Avatar
    11-12-2005
    Paterson TGCNJ
    1,940
    Which item? the JDM strut bar?
  2. #42
    12-17-2002
    Sherman Oaks, California
    4,304
    if anyone can actually find where to buy the 4point underbraces for the 7g, ralliart, cusco, doesn't matter, i will personally suck them off
    http://socallifestyle.com/
    1994 Galant GS 5spd
  3. #43
    12-17-2002
    4,304
    seriously
    1994 Galant GS 5spd
  4. #44
    Proto
    Does the 2g one fit?
  5. #45
    12-17-2002
    4,304
    yes
    1994 Galant GS 5spd
  6. #46
    Proto
    Only ones I found were 2 point. There is a 4 point for the Evo though.
  7. #47
    Quote Originally Posted by Proto View Post
    There arent any 4 point made for 7g galants or 2g Eclipses. All Ive seen is evo and mirage ones. The idea is to find one off of 8g VR4, cuz they have the same suspension as ours
  8. #48
    12-17-2002
    4,304
    there's a 4point made by ralliart, i know this for a fact, the cusco one hasn't been confirmed.
    1994 Galant GS 5spd
  9. #49
    The ralliart one isn't in production anymore and was never marketed over here so it would be by the grace of god that you could find one.
    222whp/250wtq
  10. #50
    11-12-2005
    Paterson TGCNJ
    1,940
    In the past I've had 2 JDM sources scour
    junkyards and ralliart suppliers but no luck.
  11. #51
    12-17-2002
    4,304
    dohcstunr has the 4point ralliart in red....IT IS POSSIBLE!!!
    1994 Galant GS 5spd
  12. #52
    11-12-2005
    Paterson TGCNJ
    1,940
    Agreed. There's more out there somewhere.
    ...somewhere. :neutral:
  13. #53
    Sirs I'm using the 8g jdm strutbar how can I correct the hood because the strutbar created a little hump outside and a bit noticeable . I already adjusted the rubbers in front and the hood sits a bit higher. I want to return it to original without the hump. is that posiible? what about hammering a bit on the inside of the hood? btw mine is sohc.thanks!
  14. #54
    Proto
    Jump on the strut bar a bit (assuming you have some weight) and it will bend it just slightly and allow the hood to close tight.
  15. #55
    I'll try this one but use some weight or heavy stuff. I'm skinny.lol
  16. #56
    12-17-2002
    4,304
    welcome to the kia forums
    1994 Galant GS 5spd
  17. #57
    Quote Originally Posted by romtrt View Post
    i had that problem, i cut the part of the skeloton under the hood
  18. #58
    Quote Originally Posted by kolio View Post
    Thanks kolio! how did you do it? tools you use or can you post a picture of it? I really appreciate your help. thanks!
  19. #59
    i put blue painters tape on the strut bar sticky side up and let it stick to the skeleton. then i used the dremel to cut it away. i will take pics of it tomorrow.
  20. #60
    thanks! will wait for the pics.
