Thread: Any body know to...
Showing results 1 to 8 of 8
    Any body know to...
    replace a wheel stud on the front of a 2000 G ? I got one stripped on my driver front and need it replaced...I got the wheel off, and the caliber off. But that's as far as I got.
    i know the search tool does...you can ask it.
    04-13-2005
    Chicago
    1,945
    Re: Any body know to...
    <div class='quotetop'>QUOTE(00GalantMan)</div><div class='quotemain'>replace a wheel stud on the front of a 2000 G ? I got one stripped on my driver front and need it replaced...I got the wheel off, and the caliber off. But that's as far as I got.</div>
    forget about it man...... just hit it with a hammer from the outside in.... then just tap the new stud in. it should be an easy job.. pm me if you need more help.
    n3oAcid24 = 01' Galant I4
    Yeah tap it out with a hammer or should i say bang it out! lol and once you put the other one in your are going to need a air ratchet and some washers. Slide the washers on to the stud and start the lug nut on there and then just drive it until the backside is flush to the hub and then your done.
    <div class='quotetop'>QUOTE(00GalantMan)</div><div class='quotemain'>Dont you think i did that already</div>
    actually no.
    but you guys want hold my hand picture tutorials right?? here's one i just made
    step 1
    step 2
    step 3
    now go ahead and tell me the search tool doesn't work.
    04-13-2005
    Chicago
    1,945
    04-13-2005
    Chicago
    1,945
    <div class='quotetop'>QUOTE(pinoyesv6)</div><div class='quotemain'>you guys want hold my hand picture tutorials right?? here's one i just made
    step 1
    step 2
    step 3
    now go ahead and tell me the search tool doesn't work.</div>
    dont worry man.... i got it.
