Thread: clutch change...
Showing results 1 to 2 of 2
    clutch change...
    I have a Fidanza flywheel and Centerforce clutch I am going to put on my car, only thing is, I've never done a clutch change on one of these cars before. I have a 90 GSX and was wondering if anyone knows of problems I may encounter during this work, and, if there are any pointers anyone knows of in how to make this easier. I've replaced engines and clutches, but never on a Galant, and never on a 4WD/AWD vehicle, but looking at the setup it seems pretty strait forward. Any and all help is very much appreciated.
    1990 Galant GSX: HKS Super flow, front strut bar, KYB coil overs, UR underdrive crank pulley, Greddy Kevlar Timing belt, Revolution muffler, custom grounds, Center Force clutch, Fidanza flywheel, Pace setter header, 4 wheel cross drilled rotors
    Jamie@WORKS
    http://www.vfaq.com/
    Specifically: http://www.vfaq.com/mods/clutch-1G.html
    Once the transfer case comes off, it's like working on a FWD car
