Turbo question??
Wheres a good place to tap on the 4g64 for the wastegate acuator,bov and boost gauge?? I need dependable/acurate spots!!!
The biggest line coming off your intake manifold.
Is that the one that the FPR is hooked to?
you technically want any vacuum line. for the wastegate actuator, run a vacuum line off a nipple from one of your charge pipes, preferably the J-pipe coming off the turbo. for the boost gauge you should T off the vacuum line on your intake mani going to your fpr
