Thread: Finally Ive finished my swap! Somethings wrong.. vid
Page 3 of 7 FirstFirst 1234567 LastLast
Showing results 41 to 60 of 130
  1. #41
    Ok well today (mon) I will be able to work on my car and had a few questions. 1) should I use locktight on the flywheel bolts?(2) When I ran the shifter cables the rubber piece is not touching the firewall its about 2 inches away from it. Ive tried wiggling it but nothing. What to do? Also ill takes some pics when its not 3.00 am Lol. But I should be finishing tomorrow so hopefully everything goes smooth.
    ^The info is in the sticky posted in this forum here
  2. #42
    Ok as of now everthing is finished but.............. As i was walking picking up some tools i came upon this and have no clue to where it goes.. I think it might of came from under the car.
  3. #43
    MaZeltov!!!! Its a 5spd.
  4. #44
    yeha dude thats one of the tranny perch brackets.
    can't tell which one though.
  5. #45
    <div class='quotetop'>QUOTE(DOHCstunr)</div><div class='quotemain'>yeha dude thats one of the tranny perch brackets.
    can't tell which one though.</div>
    Edit: I found what it was , its a perch from the A/T . So finally I am done!!!
  6. #46
    <div class='quotetop'>QUOTE(gravy)</div><div class='quotemain'><div class='quotetop'>QUOTE(DOHCstunr)</div><div class='quotemain'>yeha dude thats one of the tranny perch brackets.
    Edit: I found what it was , its a perch from the A/T . So finally I am done!!!</div>
    sounds great.
    but you aren't done till its done lol.
    congradulations though,
    drive it yet?
  7. #47
    Dont forget the inhibitor switch wires. Glad you made it and didnt give up. Sounds like that stupid bearring is the hardest part of the swap for you AT guys!
  8. #48
    Well I havent drivin or even started the car yet. I bought some bake pads which Im gonna put in. then I came upon this
    I look for where it plugs in and found that it goes on the tranny on the right side(facing front of car) So my question is where do I connect it to?
  9. #49
    <div class='quotetop'>QUOTE(gravy)</div><div class='quotemain'>Well I havent drivin or even started the car yet. I bought some bake pads which Im gonna put in. then I came upon this
    I look for where it plugs in and found that it goes on the tranny on the right side(facing front of car) So my question is where do I connect it to?</div>
    i'm pretty sure thats the harness i included for the reverse lights switch.
    i'm not sure how to splice it in cause i don't know the wirign for the 7g auto harness. but it shoudl be very simple.
    one of the guys ought to have the scematics.
  10. #50
    12-17-2002
    Sherman Oaks, California
    4,304
    about 3 other members and myself don't have our reverse lights because we still havn't figured out how to wire it into the auto harness
    and because i havn't combed the electrical service manual yet
    dohcstunr suggested: wire the reverse lights to a constant or switched 12v. run their grounds up to the front reverse sensor on the tranny, and wire that to a ground. theoretically, should work...damn good idea too
    http://socallifestyle.com/
    1994 Galant GS 5spd
  11. #51
    Bronx NYC (reppin)
    3,489
    Congrats Dude, have you decided to drive it yet?
    Drive It Like You Stole It!
    7G Erubini Body Kit for sale
  12. #52
    Member da1085's Avatar
    01-03-2006
    202
    i spliced mine on that big harnes.....if i can remember it right, they have the same colored wires.......ust match them with the tw wires on the big harnes that you crossed for the inhibitor wires....
    1990 GSX(91 eprom ecu set-up)
    6-bolt jdm (GVR4)
    16G turbo
    3inch turbo back(flowmasters)
    510cc
    OSTRICH
    FMIC
  13. #53
    12-17-2002
    4,304
    Quote Originally Posted by da1085
    are you talking about the reverse wires?
    1994 Galant GS 5spd
  14. #54
    01-03-2006
    202
    Quote Originally Posted by peanotation
    yeah......i remember reading something about it so i decided to give it a try when i was doing my swap and it worked.....i have reverse light when im i go in reverse..
    6-bolt jdm (GVR4)
    16G turbo
    510cc
    OSTRICH
    FMIC
  15. #55
    12-17-2002
    4,304
    what year is your galant? what colors are the wires? you just wired it directly into the reverse switch? haha sorry i need more details on the solution to this 2 year old problem
    1994 Galant GS 5spd
  16. #56
    01-03-2006
    202
    im going to check.......ill post the picts in like 30 mins.....
    6-bolt jdm (GVR4)
    16G turbo
    510cc
    OSTRICH
    FMIC
  17. #57
    01-03-2006
    202
    i have a 97 ES ......i finished my swap about a month ago.....i was reading the old post and i came across one that siad which one to connect it to....well i when i did mine i wrapped everything so it would be kinda hard to look at the harness but the color should be the same as the one on the connector......the connector are red with s striped color on it....red with blue(or green can really tell on mine).....the wire are the same gage wire....
    if you guys really want to me to rip off my wire cover then i'll do it but i dont really feel like taking it off.....but let me know
    6-bolt jdm (GVR4)
    16G turbo
    510cc
    OSTRICH
    FMIC
  18. #58
    +2 what hew said on mine the wire is red with a blue stripe
  19. #59
    01-03-2006
    202
    Quote Originally Posted by gravy
    the wire you connected them to on the big harnes had about the same colors right???
    6-bolt jdm (GVR4)
    16G turbo
    510cc
    OSTRICH
    FMIC
  20. #60
    Right, it was pretty much the same wire
