<div class='quotetop'>QUOTE(gravy)</div><div class='quotemain'>Well Im gonna start again tommorrow mornig and i'll see what i can get done in 3 days. I used the manual starter btw. Atleast I wont have to go through the entire swap again so i guess thats good.</div>
seriously man it won't be that bad...
at this point all the rusty suspension parts you had to battle have been broke loose.
so that hassle goes away,
second,
you know exactly what you are doing and have physically done everythign you need to do to get where you want to go
^if that makes sense lol.
either way,
you shoudl be able to get that tranny off in a matter of hours.
key things,
you don't have to drain the clutch line,
just unbolt the slave from the bellhousing and sit it off somewhere out of the way.
other than that just yank those axles out and do your business. be careful not to seperate the c/v joints when you are taking the axles out.
as soon as you get inside the bellhousing the problem shoudl be evident.
look for signs of interference.
