Thread: Finally Ive finished my swap! Somethings wrong.. vid
Page 7 of 7 FirstFirst ... 34567
Showing results 121 to 130 of 130
  1. #121
    Kansas City, MO
    1,244
    ok now i have a problem with my swap. won't go int ogear when the car is on, but will go into gear when the car is off. while on, reverse has the gear grinding sound.
    before i put the wheels back on and lkowered the car, i had my dad start it and put it in gear when it was on jacks, went into first fine, so i don't know what's up now.
  2. #122
    Quote Originally Posted by Blue Ice
    you need to bleed yoru clutch again.
    rememvber that yoru clutch line was completely bone dry when you installed it, so there is potential for a LOT of air,
    after you rebleed it and drive for a day or two,
    bleed it again.
    wait for the airbubbles to collect together as a few large bubbles, instead of hundreds of tiny ones.
    did you use a used master and slave or new?
  3. #123
    Bronx NYC (reppin)
    3,489
    no offense but...
    :Fuckyou:
    oh by the way do you have any extra m/t front mounts lying around you could send me.
    I have a brand new front and rear M/T mount right now ready to be shipped. PM me
    Do what DOHC says but also try to adjust the pedal clutch afterwards, it might not be fully engaging while the car is running.
    Been there done that! Nuff said.
    Drive It Like You Stole It!
    7G Erubini Body Kit for sale
  4. #124
    Kansas City, MO
    1,244
    yeah i talked to dohc on the im sunday night and i had to do a couple of things, but they all involved the clutch pedal. pretty much, adjusted the pedal all the way out, and then adjusted the master clutch rod to fit up to the pedal.
    bled the lines and now everything is good to go.
    Drove it last night for about 40 min and everything seemed to be ok. tranny hadn't been used in a while so i had to break it in a little.
    Bronx PM sent today.
  5. #125
    12-17-2002
    Sherman Oaks, California
    4,304
    i just want to point out....I HAVE REVERSE LIGHTS.
    i was reversing out of my parking spot last night, and the car behind me reflected my nice, shiny, hyperwhite, bright REVERSE LIGHTS Aahhhhhhhh reverse lights!
    thanks so much again da1085 and gravy!!!!! REVERSE LIGHTS PWN JOOOOO!OOOOOOO
    edit: oh, in case i forgot to mention, REVERSE LIGHTS ARE MINEEEEEEEE
    http://socallifestyle.com/
    1994 Galant GS 5spd
  6. #126
    GRAVY!!!!!
    WHERE ARE YOU MAN??????
  7. #127
    I need to hook up my reverse lights hmmm. So how does it work? Wheres the wiring diagrams, feed me the info!
    <span style="color:white">haha just kidding Im not a n00b who doesnt know how to search</span>
  8. #128
    Bronx NYC (reppin)
    3,489
    Seth, are you joking?
  9. #129
    Well its been a while without an update. The car sat in the garage for over 3 weeks because I wasnt able to work on it. I finished the swap in no time, but in the process ruined my extra axle. As of now I still havent order a new one but from what I can tell everthing is fine and working on the car.
  10. #130
    Quote Originally Posted by gravy
    dude i thought you were dead!!
    lol
