did you replace the struts at the same time?
ok i lowered my car about 2 inches with dropzone springs i got them on the front end is fine but the back is bouncing like a camel. on a regualar pavement its bumpy like its suposed to but with you hit a bump bump at 45 it doesnt want to go back to nomal it keeps rocking and hte front is still fine its weird! I think it mgith be that sweetspot where it used to sit got warn out inside the shock i donno i really need some help email me at [email protected] i mgiht forget to check back lol but ill try.. ill write it on my forhead. I also never hcanged out the shocks i got a 2000 tonight please some help..
<a href="http://s40.photobucket.com/albums/e202/duh2150/?action=view&current=crownvicbannerpart3.jpg" target="_blank"><img src="http://i40.photobucket.com/albums/e202/duh2150/crownvicbannerpart3.jpg" border="0" alt="Photobucket"></a>
no i just replaced the springs shouldnt they of still worked?
Sounda like you have bad struts....
Your are riding on pure spring, my friend. Your oem struts are done.
<div class='quotetop'>QUOTE(duh2150)</div><div class='quotemain'>no i just replaced the springs shouldnt they of still worked?</div>
They work, but based on age, mileage, they probably should have been replace anyways. Now its just amplified the poor condition of your factory struts with lowered coil springs.
dropped springs + oem struts/shocks (most often) = bouncy ride
Here is where it gets expensive:
$245 (average) to replace whats there:
http://cgi.ebay.com/ebaymotors/KYB-GR-2-GR...sspagenameZWDVW
$355 (average) to upgrade from whats there:
http://cgi.ebay.com/ebaymotors/KYB-AGX-STR...sspagenameZWDVW
Now you are in my boat.
Good luck
8G 4 life!
Mods: CAI,Grounding wires, CCorners, Shaved, 3G STB. AGX/Teins, Addco bar, OZ F1 wheels And well maintained : )
:shock: ill just buy the back shocks first but then might by the front the front is perfectly fine.
