Thread: Rubber seals
Showing results 1 to 6 of 6
    Senior TGC Member
    2,175
    Rubber seals
    Anyone else having their window seals starting to crack and peel into little strips?
    Nope, not here. Guess weather is pretty harsh in your neck of the woods. Got to pamper those trims from day one if you want them to remain supple. If by the time you find that they are starting to crack or something, it's too late. :cry:
    Jeff
    Quote Originally Posted by TJC
    how do you pamper the seals, so I can start now...never thought about them going bad....it's always the little things that slip my mind.
    Senior TGC Member
    2,175
    Mine looks like someone took a knife to it and slit little strips or cut badly from the factory...imagine a pom pom
    Quote Originally Posted by jeffs2k1
    i just clean it with a lil bit rubbing alcahol from time to time. along with my wiper blades
    Products made for cleaning and putting back luster into vinyl and rubber will do. Meguires makes one and I'm sure there are many others too. I'd stay away from Armour All and alcohol based products as those take away moisture from rubber and vinyl. Keeping the car generally clean also helps and if you can keep car in covered parking, over time that adds up to a lot of hours you don't have the car out in harsh weather.
