Thread: Boost question
Showing results 1 to 4 of 4
    mbssbm
    Boost question
    What do you guys mean by boosting, what is it? How can I do it?
    most people mean using some kinda of forced induction method. either by means of dropping a super charger, or a turbo. spraying is another term u might hear, that involves the use of things like nitrous oxide
    yangjiesheng
    I'm currently owning a VR4 V6 2500cc twin Turbo..
    Its a force induction of Air through by the exhast.. header that spin the
    turbo.. and drug in more air into the engine.
    Combine with the fuel mixture chip management..
    If Just push yourself against the driver seat and the car goes like HELL.
    You can check out these web site to further understand.
    http://www.howstuffworks.com/turbo5.htm
    Hopefully it helps
    Regard
    Jason
    09-22-2002
    Kissimmee, FL
    1,495
    Inline 4 motor 4G64, spraying about 125-200 shot of nitrous oxide combined with 110 octane, had break neck speed with just a push of a button.. one of the fastest Galants on the board, besides AK1.. quater mile time 13.5, rec. 5.34, spd. 103.37mph..
