Thread: Who knows about Immobilizers in 8g ecu's
Showing results 1 to 11 of 11
    Question: Do the 8g's have an immobilizer (anti-theft) in the ecu?/Does it have an immobilizer code such that it needs to have a key/chip nearby for it to work?
    Thanks
    the 99s don't. From 2000 up they do. If you look at the back of your fuse box under the dash you'll see a yellow sticker. On that sticker it'll mention if the car is equipped with an immobilizer, power trunk release, factory alarm, keyless entry, and some other stuff which escapes me at the moment.
    In the last 2 months i became a master in the mitsu security world, let me know if you need so help with something. I also have a few ways of flashing new codes and making other ecus work with our cars.
    11-24-2002
    Originally TGCNY, Now TGCTX
    1,781
    As i understand it, the 99 Does have an immobilizer. I can confirm that it doesn't ahve a key though. Don't ask me how it works.
    -Pedro
    Ok let me reword what I meant. The 99s don't have a chip in the key. 00+ do have chips in the keys. However all 8gs have an option for a factory alarm. To check if your car has a factory alarm:
    1. Roll down the driver's window.
    2. Close all of the doors, hood, and trunk.
    3. Put the key in the drivers door and turn the key to lock the door.
    4. Wait about 15 seconds
    5. Reach in the drivers window and manually open the door.
    If the horn goes nuts and the parking lights start flashing then you've got a factory alarm. Thank you driver thru first window.
    hmm..ok cool - thanks for that info i have a 99 lol
    08-06-2005
    Long beach/ guam
    1,585
    hehehehehe i kinda feel safe now.
    11-05-2003
    San Francisco Bay Area
    1,517
    <div class='quotetop'>QUOTE(GOOSEY2099)</div><div class='quotemain'>In the last 2 months i became a master in the mitsu security world, let me know if you need so help with something. I also have a few ways of flashing new codes and making other ecus work with our cars.</div>
    A bit off topic, but have you gotten the 3G Eclipse ECU to work on the 8G?
    <div class='quotetop'>QUOTE(DryBear)</div><div class='quotemain'><div class='quotetop'>QUOTE(GOOSEY2099)</div><div class='quotemain'>In the last 2 months i became a master in the mitsu security world, let me know if you need so help with something. I also have a few ways of flashing new codes and making other ecus work with our cars.</div>
    A bit off topic, but have you gotten the 3G Eclipse ECU to work on the 8G?</div>
    Yep, I also had another one did another one for David(02Galant).
    HI. A have a Galant GTZ 01. V6. My Car dosnt work, it Cracks when I turn on the key. But it dosnt start. I think a relay dont work, or the Factory alarm activate the Anti-Teft System. How I could desactivate anti-teft System? I havenĀ“t the alarm Control.
    ECU issue
    Can a 2001 ecu and ignition switch be flashed to work in a 2000 mitsubish galant
