open your trunk. go to the tails. there are like ome plastic nuts that hold in the carpet where the tails are. remove them. its like 3 or 4. then once that is removed, there are 3 bolts that hold the tail light in. remove those nuts and take the tail lamp out. then all u do is unscrew the socket from the light and replace the bulb. once u do that, put everything back together
