If you have the paint code (P78) you can just go to any automotive paint store (look in yellowpages) and they can mix some up for you. The smallest amount they will mix is a pint. Red paint is the most expensive so it will be around $30-40 for the pint. Other paints, like white or black will be closer to $20 for a pint.
You will need a spray gun to apply the paint, unless you specifically ask for a paint that DOESNT need a catalyst, in that case they can usually put some in a rattlecan for you.
