I dont think you realize that the fenders on a galant are cut lower in the back than in the front. The front APPEARS to sit higher when in reality its sitting a slight bit lower. You would be better off going with a even drop, if you go that agressive of a difference, your handling is going to be all over the place. I suppose if you really want to do it, you could mix and match kits; say maybe the front springs from the Eibach sportline kit and the rear springs from the Eibach pro-kit. thats just my 2 cents.
