the 01 kia rio fits are cars Perfectly..and if u search you'll find in detail what you need
So what is the best manual tranmission out there to get for a swap in a I4 8G?
00 Galant ES Turbo/5-Speed
13 GTR
<div class='quotetop'>QUOTE(IceDouTGaLanT)</div><div class='quotemain'>the 01 kia rio fits are cars Perfectly..and if u search you'll find in detail what you need Â* Â*</div>
ahaha...newbie, please search...
I love Kia
kia??? really??
<div class='quotetop'>QUOTE(milo111000)</div><div class='quotemain'>kia??? really??</div>
I'm not gonna answer that, but if you have a 2002 you are gonna have a HELL of alot of trouble getting rid of the CEL codes that come with the manual swap. 02 is not like an 01 the wire harness is different for the ecu so you can't even swap it out for a 2000 ecu that has no problems. Good luck and read my tutorial in my sig
<div class='quotetop'>QUOTE(GOOSEY2099)</div><div class='quotemain'><div class='quotetop'>QUOTE(milo111000)</div><div class='quotemain'>kia??? really??</div>
I'm not gonna answer that, but if you have a 2002 you are gonna have a HELL of alot of trouble getting rid of the CEL codes that come with the manual swap. 02 is not like an 01 the wire harness is different for the ecu so you can't even swap it out for a 2000 ecu that has no problems. Good luck and read my tutorial in my sig</div>
that's what i though.... why go kia when u got it made with the 3rd gen..
so what are us 02 owners to do about the CEL codes then? it wont affect anything will it?
2004 Nissan Maxima3.5 V6 DOHC
So what do you suggest I do with this I4 2002 Galant. How can I get the most power out of it, without it being a manual, since theres the ecu code issues.:cry: I would assume a manual 2002 Galant is better than a Automatic!
Your sig? :shock:
GOOSEY2099-
Your G looks sleek!
Only reason you would have to get rid of the CEL is for emissions. My CEL is permanantly on, does it bother me? No. I am too lazy to wire up the soleniods that are causing it to be on.
If a little red light bugs you, put a piece of tape over it or disconnect the bulb.
If there is something wrong with the car you will be able to tell from how it drives/sounds. Then just rescan it and ignore the TCU codes or whatever. Sounds good to me?
<div class='quotetop'>QUOTE(2002GMS)</div><div class='quotemain'><div class='quotetop'>QUOTE(GOOSEY2099)</div><div class='quotemain'><div class='quotetop'>QUOTE(milo111000)</div><div class='quotemain'>kia??? really??</div>
Your sig? :shock:
GOOSEY2099-
Your G looks sleek!</div>
You should see it in person. I want jdm because of his car. DAMN YOU ROMAN!!!!!!!!!!!
<div class='quotetop'>QUOTE(seth98esT)</div><div class='quotemain'>Only reason you would have to get rid of the CEL is for emissions. Â*My CEL is permanantly on, does it bother me? Â*No. Â*I am too lazy to wire up the soleniods that are causing it to be on.
If there is something wrong with the car you will be able to tell from how it drives/sounds. Â*Then just rescan it and ignore the TCU codes or whatever. Â*Sounds good to me?</div>
It doesn't work that way here, if you have a check engine light in ny/nj and other areas you won't be able to pass inspection. I'm currently helping David(02galant) with this problem. Right now we are trying to figure out how to get an 01 ecu to work on a 02 g. Seth if you can figure out how to get rid of those solenoid codes that would be one of the biggest contributions to this project. As far as my sig, I meant click the 5spd link in it. You'll find alot of pictures on how to do the swap and what parts are needed. If you want the most bang for the $ in G, I would recoment to go nitros. This is not something i would usually suggest but it will be a lot cheaper then any FI projects. I would also try reading more about this on club3g and remember that "galant/eclipse" + "cheap" are not in the same dictionary.
<div class='quotetop'>QUOTE(milo111000)</div><div class='quotemain'><div class='quotetop'>QUOTE(GOOSEY2099)</div><div class='quotemain'><div class='quotetop'>QUOTE(milo111000)</div><div class='quotemain'>kia??? really??</div>
that's what i though.... why go kia when u got it made with the 3rd gen..</div>It was a joke
do the 03 I4s have the same problems as 02's. and is there anything to learn from the 3G eclipse to solve these problems.
* KYB GR-2 shocks and struts $210
* Progress Technology lowering springs $157
* Lowering your own car for the first time, priceless.
I had a CEL on when I had to get my car inspected.. I just yanked the cluster and removed the bulb temporarily
<div class='quotetop'>QUOTE(GOOSEY2099)</div><div class='quotemain'><div class='quotetop'>QUOTE(seth98esT)</div><div class='quotemain'>Only reason you would have to get rid of the CEL is for emissions. Â*My CEL is permanantly on, does it bother me? Â*No. Â*I am too lazy to wire up the soleniods that are causing it to be on.
It doesn't work that way here, if you have a check engine light in ny/nj and other areas you won't be able to pass inspection. I'm currently helping David(02galant) with this problem. Right now we are trying to figure out how to get an 01 ecu to work on a 02 g. Seth if you can figure out how to get rid of those solenoid codes that would be one of the biggest contributions to this project. As far as my sig, I meant click the 5spd link in it. You'll find alot of pictures on how to do the swap and what parts are needed. If you want the most bang for the $ in G, I would recoment to go nitros. This is not something i would usually suggest but it will be a lot cheaper then any FI projects. I would also try reading more about this on club3g and remember that "galant/eclipse" + "cheap" are not in the same dictionary.</div>
What codes does it give you exactly? Isnt the trans ECU and Engine ECU the same unit in the 8g? Cant just switch over to an 01 ECU? I swapped to a 2g Eclipse ECU and just had to move around/add a few wires. I wouldnt think that within a year, Mitsu totally changed how the ECU worked in the same model vehicle.
Thanks for the info. Is that possible to throw nitros on a I4?
<div class='quotetop'>QUOTE(2002GMS)</div><div class='quotemain'><div class='quotetop'>QUOTE(GOOSEY2099)</div><div class='quotemain'><div class='quotetop'>QUOTE(seth98esT)</div><div class='quotemain'>Only reason you would have to get rid of the CEL is for emissions. Â*My CEL is permanantly on, does it bother me? Â*No. Â*I am too lazy to wire up the soleniods that are causing it to be on.
Thanks for the info. Is that possible to throw nitros on a I4?</div>
yes.
and now that you've got the answer do some reading becasue being spoon fed means you miss a bunch of info that can help you as well. up at the top of this page there is a search link which searches the board for the information you want to see (it's right between the FAQ and member list links). if you still can't find it, click here. no when you get there, type in what you are looking for then select "Search for all terms" (it's the second radio button); that will narrow down your results since there are probably hundreds of posts on any question you have. this board, in it's current state, has been up for most of 5 years, and we have 8 thousand+ members; any question you might have has allready been addressed. now if you have a question that hasn't been asked, ie. a very specific or new question, everybody here would most likely try to help. welcome to TGC.
<div class='quotetop'>QUOTE(seth98esT)</div><div class='quotemain'><div class='quotetop'>QUOTE(GOOSEY2099)</div><div class='quotemain'><div class='quotetop'>QUOTE(seth98esT)</div><div class='quotemain'>Only reason you would have to get rid of the CEL is for emissions. Â*My CEL is permanantly on, does it bother me? Â*No. Â*I am too lazy to wire up the soleniods that are causing it to be on.
What codes does it give you exactly? Isnt the trans ECU and Engine ECU the same unit in the 8g? Cant just switch over to an 01 ECU? I swapped to a 2g Eclipse ECU and just had to move around/add a few wires. I wouldnt think that within a year, Mitsu totally changed how the ECU worked in the same model vehicle.</div>
There are 3 basic types of ecus for the 8g family. 99,00-01,02-03. They aren't interchangeble. If you have a 2001 galant you will have a CEL light but you can allmost easily swap out to a 2000 ecu like i did and everything is fine. If you have a 99/2000 v6/i4 you will have ZERO problems with this swap. Now for the 02-03 thats something that needs to be figured out. Like i said i'm working on this and hopefully we'll be able to get this figured out soon.
