Yes you can. The next issue is $$$.
Can I swap the 2002 bumper and grill with the 2001 bumper and grill. Curious?
8G 4 life!
Mods: CAI,Grounding wires, CCorners, Shaved, 3G STB. AGX/Teins, Addco bar, OZ F1 wheels And well maintained : )
There’s a tutorial some where around here about swapping 02-03 bumper to 99-01 bumper.
SEARCH hint... hint....
TURBO= in the making.......
<div class='quotetop'>QUOTE(SLS2000)</div><div class='quotemain'>Yes you can. The next issue is $$$.
</div>
What would it cost. Cause I really like the VR-4 bumber, and grill. If I can do the swap, I'd do it.
<div class='quotetop'>QUOTE(zobgel)</div><div class='quotemain'>There’s a tutorial some where around here about swapping 02-03 bumper to 99-01 bumper.
SEARCH hint... hint....</div>
I've searched but nada. But thanks I'll keep looking, cause I really want to do this..
it should be pretty much a bolt off bolt on kinda deal.
for 02-03 to fit the 99-01 bumper cover and grill, you need to cut off the center "nose" support to get the 99-01 grill to fit. Not sure, but I think the bottom mounting tabs underneath the bumper cover are different, but I'm not even using those due to my intercooler, so I don't think that would be a problem.
Really! Sound easy! Do you know where I could get good deals on VR-4 grills and bumpers? Which seem really hard to come by...Originally Posted by pinoyesv6
Originally Posted by DryBear
What is the center noise part made of? Also is there a function for it?
Thanks!
I hope that this is really possible! I cause I've able to find the VR4 Grille. But still looking for the bumper. If anybody has any information on where I could get the VR4 bumper! Please let me know or even the grille as well. I'm interested!!!Originally Posted by 2002GMS
Thanks!
well you lose the center nose piece when u remove the 02 bumper. but the metal support piece is still there. you just cut it off with a cutting wheel.Originally Posted by 2002GMS
But other wise It should fit? Like is the bolting, and stuff still the same? When adding the VR4 bumper?Originally Posted by pinoyesv6
Thanks man!!
depending on which vr4 bumper you get there may be a little modding you will definatelly loose the foam in front of the crashbar and my have to trim the sides also if you go jdm you will need the jdm heads which do require modification to fit
there is a groub buy going on right now for jdm kits you can ordr the pieces or individual parts look in the GB section
Hey thats funny i'm selling my front and rear bumper with the grills and its already painted (silver) just give me a call if you are still looking my names nick 15599167165
oh yea it's an 02
JDM's! I want the vr4 grill and bumper.Originally Posted by LTK
