Originally Posted by
peanotation
the head won't help your current situation, which is running a safe and humble tune. all that will do is add more power, something you really shouldn't be interested in at this point in time.
upgrading engine internals, in retrospect to this discussion, is something you need to forget about entirely for the time being.
with that being said, you can slap on a turbo with the shittiest tune in the world and run 8psi NO PROBLEM. a week later, be sure to mount a camera in your engine bay so we can see the block split down the middle.
it's all about reliability and efficiency, with practicality mixed in the middle. guys have been runing 8psi on stock internals on the 4G64 for YEARS, but their tune and driving method is all key here. if you're going to be one of those guys that's going to showboat to his buddies all night by doing 5th gear pulls down the highway at WOT for hours on end, then maybe engine internals is something you should consider upgrading at this point, in which case, i recomend you do nothing but read for the next year before you buy a single part.
with a moderatly rich tune (~10-11.0 on the wideband), 0 knock, and nice low EGTs, you can run 8psi on the 4G64 until the apocalypse, assuming you don't drive it like a total dipshit.
plan your turbo build in two seperate parts: physical, mechanical components (which turbo you gonna run? what injectors? what size charge pipes? etc etc) and the electrical, tuning area (GM Maf, megasquirt, MAFTpro, standalone, piggyback, speed density, injectors in the intake, etc etc.) of course, when i say plan it two seperate parts, there should be some communication between the two (injectors vs. tuning option, yadda yadda)
as said before, for $1000 you're not leaving us a lot of options to reccomend to you. i have billions of ideas flying through my head but i can't say a single one because of your redicously low budget.
personally, i am completely against piggybacks (with the emanage being the only exception). i never had good results with my s-afc2, and guys using them on the 2G were only using it for moderate adjustments, not complete fuel map realignments like we need on the N/A ECU.
standalone is the shit. it covers all your bases. it is truly the most controlled state of tuning you can purchase. but unless you have a team of tuners standing by, or you feel like spending weeks on end programming the shit out of it, it's not practical at all for your situation, and it's expensive as all hell. especially for just a measly 8psi, it's total overkill.
GM MAF and maftpro are pretty solid. the GM Maf will read all the compressed air post-turbo and let your ECU actually know how much air is going into the engine. maftpro is something you should read up on, being different and the same all at the same time.
speed density is the shit. enough said.
anyone feel to correct me of i mistated something, i'm more drunk than the pope on new years right now.
