Thread: Racing Tip
Showing results 1 to 11 of 11
    Racing Tip
    I have been challege by a honda to race. I do not have any thing done to my car to race it. I know that my care take off slow. Is there any thing u gays can tell me what to do to increse the speed of the car and the take off. I have a 2001 ES I4 model.
    Try to start from the loewest Gear and hit 5500 RPM and work u're way up !!! or intall a NOS what kind of Honduh ??
    Sex is when a guys information
    enters a girls communication
    to increase the population
    for a younger generation
    do you get the information...
    or do you need a demonstration ??
    Honduh sux also if u want to add some power, try to use some 100 octane fuel, the 1 they use for Nascar, some 76 have em here in CA.
    I Dont want to use Nos. Is their another was to gain speed quicker. I read about how to let you car know that you are a hard driver in one of the forums
    Black2k1GTZ
    Going faster will help but you will want to make your car lighter too. Take out the spare tire and the jack. And make sure you turn off your a/c and the radio. That will make the power that you do have more effective!!
    Marc :mg:
    race with your tank almost empty. gas =weight but yea don't run out of gas when u race too haha that would be funny
    Get some turbo's, its better than NOS .
    cdaw2001ES
    Quick tips,
    get a Cold Air Intake ($250). Racing Headers ($268), New Cat Converter, pipes and muff back($250), a new Fuel Pressure Regulator ($250), Some new plugs, and wires($35-150) and possibly an S-AFC ($$$???)
    If the Honda is stock, you should have no trouble.
    Supernova
    <div class='quotetop'>QUOTE(cdaw2001ES)</div><div class='quotemain'>Quick tips,
    If the Honda is stock, you should have no trouble.</div>
    Thats what i'm screamin right there.
    And one thing, when you start off in low and gas it... do you let off the gas each time you change gears in an Automatic?
    MnGalant
    Hold the brake down a couple of seconds before takeoff well you are pushing the gas. Get the tach about to 2500 or 3000 . When it turns green let of brakes fast and slam gas all the way down. Dont hold it down to long though cause it will fry your tranny fluid and could hurt the tranny. I dont reccomend you do this and im not responsible for any damage or harm caused by this but this is how you can get an advantage.
