the preload can't be set on the ss-p.
the only way to set the preload is if the shock height has a separate threaded adjustment than the springs. (for example on the tein flex, or the jic magics)
the preload adjustment compresses the springs to get the spring rate you want. then you adjust the shock height separately to get the height you want.
http://www.roadraceengineering.com/3g/part...jiccomplete.jpg
for example look at the threaded shock body. its threaded all the way down. u can adjust the spring compression at the top of the shock body. at the bottom of the shock body u can adjust how high or low the actual shock sits inside the shock housing.
