So if you use the 3rd gen Eclipse steering wheel, which is OEM, can you use the airbag module from the Galant wheel?
well actually i am not really feeling the glossy black so i am probably going to end up changing it to a flat black instead. as far as chipping or scratching the only problem i am having is on the arm rest, it is rubbing off a bit from the seatbelt but as soon as i can figure out how to cover that with suede that wont be a problem anymore :) thanx for all the complementsOriginally Posted by fatal1
01 Galant ES V6 R.I.P
ROB
U.S ARMY...THANX FOR YOUR SUPPORT
2003 Dover White Mitsubishi Galant ES
1997 Tarmac Black Mitsubishi Eclipse GST
good point...im sure you probably can but i didnt even try to take that piece apart as the steering wheel i bought came with the airbag module allready attached to the wheelOriginally Posted by proteusx301
ROB
nice. i replaced mine quite a while back.. pretty good job
just out of curiosity, where did you get the steering wheel with the airbag already attached?Originally Posted by silveresv6
i wonder if the airbag still works...
If its plugged in, I don't see no reason it wouldn't work.Originally Posted by pinoyesv6
i went on over to the 3g website and just posted up a request for the wheel w/airbag and also got front and rear black seatbelts as well.Originally Posted by proteusx301
Originally Posted by pinoyesv6i agree. dont see why it wouldnt...no different than wondering if my own airbag that i removed would work i guessOriginally Posted by 4-G-rim
ROB
How much did you pay for the steering wheel w/airbag? I'm currently in search of black seat belts and black steering wheel from a 3G. :(
i was thinking that maybe the airbags worked on diffferent voltages. but i guess if the srs light doesn't come on and the air bag hasn't blown up in your face at random, then i guess it might work.
nope no srs light and no random blows yet lol as for the voltages, there is none listed on the bags themselves so since they just plugged right in i figured everything was cool.
P.S. as for changing out the actual modules from one wheel to the other, its not possible. the bag is built into the wheel piece and you can't take it apart.
ROB
