Thread: cold air intake problems
Showing results 1 to 20 of 31
    MGalantES97
    i just bought some cold air intake piping and a mas adaptor but my car keeps stalling when i come to a stop or put it in neutral or even if i let the rpms come all the way down when i shift it will cut off and when it does stay running it idles really low this really bugs me i cant figure it out
    Tallahassee, FL (FSU)
    1,324
    did you plug the sensor back in to the MAS!??!! i bet tahts why. lol
    -Chris
    MGalantES97
    no it is plugged in with out it plugged in it just idles really high but when i plug it in i idles really low or cuts off
    12-27-2005
    Charleston SC
    1,520
    My suggestion would be to.. Put the stock intake back on. If that gets rid of the problem.. then there is something wrong with the one you put on. Good luck!!!
    New Member
    08-08-2006
    Beaverton/Covallis
    65
    maybe the sensor got dirty when you took it out. When other people have problems with stalling cleaning the sensor usually takes care of it. Clean it and plug it in.
    * KYB GR-2 shocks and struts $210
    * Progress Technology lowering springs $157
    * Lowering your own car for the first time, priceless.
    1,324
    unplug the sensor, and disconnect the negative to your battery for a few minutes, reconnect the sensor and then reconnect your battery... turn your car on and drive for a few minutes regularly so the ECU can try to catch the new readings for AirFlow...
    try that and see how it goes
    -Chris
    Bronx NYC (reppin)
    3,489
    ya reset the ecu
    Drive It Like You Stole It!
    7G Erubini Body Kit for sale
    double check your connections. make sure everything is tight, secure and put on correctly.
    07-20-2003
    Orlando, FL
    3,169
    Weired...like what Quicksilver said, I would of assumed the MAS wasn't plugged in.
    1. Make sure the MAS plug if secure
    2. Reset the ECU (Unplug BOTH the negative and positive for about 10mins)
    Shadow made a good point if the problem still occurs...reinstall the stock intake. If the problem is fixed..then its something with the CAI. If it isn't fixed..then it could be a bad MAS (Could of suddenly took a crap) or maybe you just need to clean the throttle body & intake manifold.
    fastmgalant97
    i found the source of this problem ..... when my fan turns on and blows hot air on my intake the car stalls so my guess is cold air intakes dont like hot air
    Bronx NYC (reppin)
    3,489
    WRONG!
    its something else
    12-17-2002
    Sherman Oaks, California
    4,304
    <div class='quotetop'>QUOTE(fastmgalant97)</div><div class='quotemain'>i found the source of this problem ..... when my fan turns on and blows hot air on my intake the car stalls so my guess is cold air intakes dont like hot air</div>
    haha......hahahaha.........hahahahahahahahahahahah aha
    http://socallifestyle.com/
    1994 Galant GS 5spd
    07-20-2003
    Orlando, FL
    3,169
    Quote Originally Posted by fastmgalant97
    :???: I dunno man..unless you are sucking in actual fire, hot air won't make a car stall.
    Bronx NYC (reppin)
    3,489
    Are you nutso Hot Air=Stall is Wrong.
    Im sorry but I laughed too.
    AkA ILL InFeCteD
    Bronx NYC (reppin)
    3,489
    im still laughing................................. Dude try to reset the ecu again and make sure the MAS is hooked up and there are no loose hoses.
    fastmgalant97
    problem fixed once i moved the intake away from the fan it doesnt stall nemore
    so keep on laughin boys
    i'm sorry man but the fan wasn't the problem,
    do you realize how hot it gets in there?
    yor ecu is more than equipped for yoru car to drive as smooth as butter and it be 130* outside.
    that could translate to some serious underhood temps,
    the car still wouldn't stall because of it.
    my guess is you had a post mas air leak, and when you moved whatever you moved, it fixed the leak.
    Bronx NYC (reppin)
    3,489
    i agree with you DOHC
    fastmgalant97
    well i guess ur right bc its doin it again i duno what the hell to do im trin to get this thing runnin right so i can post some pics and some footage fo my distributor dohc but im having all kinds of problems now
