won't work. thats for a 7g. the years are wrong.
OK so i was online looking at things to buy and i came across a short shifter for automatics and i wasnt sure if, or how it would work http://www.andysautosport.com/mitsubishi/1...os00041837.html if anyone could give me some info about this i would appreciate it.
Who the hell would wanna buy and install a short shifter on a A/T car?
Drive It Like You Stole It!
7G Erubini Body Kit for sale
those of us who cant afford a 5sp :POriginally Posted by bronxbombr
mitsumitsu aka luke9511
understand not having a 5sp, but to install it on a auto is well...........stoopid. :)
:laughing:Originally Posted by bronxbombr
you got to understand how long the throw is from going from park to reverse. its so long! you odn't want to mis shift and go straight into neutral. you might just end up just sitting there.Originally Posted by bronxbombr
Originally Posted by SkylineG1
well it is.
is this an april fools joke? little late for that...
i dont know what it is, but i do know it is stoopid :) :):):):P)
I highly doubt there is a "short" shifter for a A/T car. The lever in a A/T shifter control assembly is usually built into one complete piece. Plus there is no need to have a "short throw" in a A/T. If you do what the shorten the height of the shifter...MAYBE you can get a different shift knob handle to which Levoc makes some.
now that makes sense
well sense were talkin about shifters and stuff related to that, am i supposed to be able to shift from drive to neutral without pressing the button?
Yes..you can shift from drive to neutral w/o pressing the button. Its only neccessary pressing the button getting out of park and putting into park.Originally Posted by luke9511
most autos work this way:Originally Posted by luke9511
you have to press the button to go from P to R.
you do NOT have to press the button to go from R to N.
you do NOT have to press the button to go from N to D.
you have to press the button to go from D to 3
you have to press the button to go from 3 to 2
you have to press the button to go from 2 to L
You do NOT have to press the button from L to 2
You do NOT have to press the button from 2 to 3
You do NOT have to press the button from 3 to D
You do NOT have to press the button from D to N
so you only have to press the button to get out of park to reverse... then when u are ready, you can just pull down straight to drive without pushing the button (must b on the brake). also if you are dropped down into first you can go straight to neutral without pushing the button (L->2->3->D->N).
^^That sounds like manualing the auto procedure.
i always had to press the button to shift out of N into D on my auto
now i have to press the clutch
ZIGONATOR
