If you are rewireing the fogs to turn on with the driving lights. None of the above. They is a tutorial with pics in the Tutorial sectionOriginally Posted by spetsnaz
I saw the pic, and it seemed that the wires were comming from that are, thats why i figured.....
Still representing for St. Petersburg, Russia
Where, I couldnt find it? I was looking to do this mod also?Originally Posted by spetsnaz
Wasnt there one using the stock switch?
There was... the was another but the link is no longer working. There was a simpler tutorial, but it could drain the battery... can anyone remind me???
I had it booked marked i will look for it. Also I believe Korty made the tutorial ask him.Originally Posted by spetsnaz
For you losers that havent been around...Fog Light Re-Wire :laughing: :laughing: :laughing:
BlackGoose
'07 Charger SXT
damn this tutorial bothers me, i feel like i could do it if there was little more explination behind it. I took some electronics classes in highschool and could probably pull this thing off, but i just dont want to screw it up.Originally Posted by GreyGoose'01
I am taking physics 2 in university, and i can calculate the amps, owhms and voltage at each resistor, but its not easy as it seems to rewire.
the re wire is not that hard. You just have to get the fuse box in the engine bay open (which gave me a little bit of a problem) then find the wire that leads to the foglights. I hooked mine up to a toggle switch and my halos come on with my fogs now. A simple 2 or 3 prong switch is all you need.
blue(on the)rims so the G crip walkin
That's cool, chromeblueES but my look is stock. Im not interested in adding any extra switches. Just want to keep it as clean as possible.
