Thread: 2.4 dohc motor swap
Showing results 1 to 7 of 7
    i after doing a little research i found out that the kia optima motor is the same as the 4g64 with dohc. the problem is the compression, which the 2006 has 10.5.1. so what im planing on is building the motor with 9.1 compression.
    Cool, why so high? 9.1 is still a bit high for FI. Well not really, unless you can tune very well.
    Quote Originally Posted by Boostedgalant56
    10.5 woudl be fun
    wouldn't be hard to boost.
    why dunt you just keep ur block and use the evo head. the evo had has stronger internals.
    Jigz-TGCIL Sosick Motorsports
    galant2002
    how much HPs will an evo head give me over all.
    05-14-2003
    Southern California
    1,404
    Quote Originally Posted by DOHCstunr
    10.5 woudl be fun
    +1 on that. Tuning wouldn't be fun.
    IIRC Matt is planning on going with a relatively high CR as he doesn't want to run high boost (no more than 12 psi).
    Quote Originally Posted by galant2002
    Please refrain from "hijacking" others threads. If you would like you can start your own thread. Though make sure to do a search as that question may have already been answered.
    Bronx NYC (reppin)
    3,489
    true..............
    Drive It Like You Stole It!
    7G Erubini Body Kit for sale
