Yep, could be tranny fluid too. Change ATF and filter, if electrodes are rounded off on plugs, change those too, change air filter, use good gas and perhaps go higher octane, use FI cleaner if your pump gas does not contain the additives for cleaning injectors.
Of course you can always start getting mods to get more performance out of your car. At 24k, you shouldn't have to worry about cylinder compression levels yet.
