Thread: does anybodys tires be cupping in the rear with uneven tread
Showing results 1 to 9 of 9
    a2ggalantondubs
    every time i take my rims off they keep cupping what causes it?
    Tiller
    you're rolling 20's... what do you expect...?
    a2ggalantondubs
    i should have known you would say that
    JUICE*USMC
    Hello I just joined but have spent lot's of time visiting this sight so your rolling on doubs I got 19's on my 2001 galant and didn't think 20's would fit did you make any mod's?
    a2ggalantondubs
    shaved fenders with spacers and the machine shop modified my struts in the rear
    Tiller
    Quote Originally Posted by a2ggalantondubs
    for real though... your're tires alingment has to be off, to fit them beasts on there...
    a2ggalantondubs
    you have to put the camber kit on thats what keeps you wheels straight but in the rear its impossible but i just got four more 20" tire on ebay for 26$ a peice
    if its cuppinng, check your tire pressure...
    Why is it impossible to correct the camber? Mine was off by 2 degrees when I dropped mine and a camber kit fixed it perfectly.
