i was about to post about the same thing, it was fine for a while(besides the sticking) and now it has some slack this is strange :-?
mitsumitsu aka luke9511
two 10mm bolts on the back of the intake plenum
just loosen them slightly
take the slack out of the cable W/O causing the throtle plate to move AT ALL.
then tighten down the bolts.
done
takes about 20 seconds
Originally Posted by DOHCstunr
If possible is there any pics of this plate, and by doing this wat effect does it have on the car. Thanx
Kevin
2006 GIXXER 600
If the cable is loose and you fix the slack the throttle response will be better.
The plate is just on the top/back portion of the intake manifold. If you to the throttle body and follow the throttle cable a few inches it will lead you right to this plate.
If you dont know where the throttle body is...
