Thread: Noise on Brakes
Showing results 1 to 8 of 8
    Like I said, 2 days ago I change my brakes. I get the ceramic duralast from autozone. I think, the mechanic forgot to put the Inner/outer shim on the passenger site, now my car is making noise when I drive. Like ( shhhhhk, shhhhk) (sorry for that explanation of the noise.). DO you think that can cause the noise? See pic # 4( top) or 5 (below) for the part.
    07-31-2002
    Bronx NYC (reppin)
    3,489
    you need the shims or brake squeal.
    Drive It Like You Stole It!
    7G Erubini Body Kit for sale
    thats what I think, Thank's for the imfo.
    Experienced TGC Member AVERAGE's Avatar
    02-09-2006
    Raleigh,NC USA
    1,085
    sorry to dig up an old thread but Im having exactly the same problem with the same pads, Where were the shims in the box? The only thing that was in my box were pads...
    Just remove and clean up the ones on the back of your old pads, and reuse them
    02-09-2006
    Raleigh,NC USA
    1,085
    I tossed out my old pads. If you are talking about the pieces that said duralast gold on them, I installed them. :?
    If you threw out the old shims & can not locate new ones or dont want to buy new ones, auto stores sell this stuff you can spray on the back of the pads to help get ride of the noise some. Some times the stuff helps some times its no good.
    make sure you also follow the proper break in procedure
