Thread: 02 Manual Swap Speedo FIX!
Page 2 of 2 FirstFirst 12
Showing results 21 to 30 of 30
    08-15-2006
    Perth Amboy, NJ
    1,558
    few more pics :)
    (Thanks for selling me the speed sensor Cali :D )
    wires (black_blue, black, and black_yellow)
    the same diagram from Figure 3. (Black_Yellow is for pin 3, Black_Blue is for pin 4, & ground is pin 2)
    run1206's Rear Disc Tutorial
    10-18-2007
    Glen Burnie, MD
    1,314
    Alrighty, on the 03 transmission there are 2 sensors on the auto transmission. The output shaft speed sensor, and the input shaft speed sensor. So between the two I would assume that the wires needed that run to c-17 would be there.
    i gotta quick question..... what if you put a 99-01 guage cluster in a 02-03 model, would you still need to run the extra wires? or would the speedometer work like nothing was there....
    isnt it possible to run wires from the black inhibitor plug to the manual trannys speed sensor? the same plug used to start the car?
    10-18-2007
    Glen Burnie, MD
    1,314
    Well I tried this out with no luck today. I took some pics of what I connected to, maybe I was just hooking up to the wrong stuff. Ill post the pics tomorrow.
    anything new on this?
    Fully Built 4G63
    HKS 272
    ported Dual Ball Bearing FP RED 84mm 25psi w/ external dump
    08-15-2006
    Perth Amboy, NJ
    1,558
    there's a big discussion on WhiteGalant's thread "Wired up the speedo and..."
    i wired it up to what i thought was pin 3 & 4 but the speedo only works when the gas tank is less than 3/4 full. Odd, i know...
    still trying other combinations but that's the only way i can get my speedo to work.
    very true but that other thread has been on hold, i think stewi has been busy... lol
    Kind of un-related but... Will the 99-01 guage cluster hook right up to the 02-03 with no modification? Or will there have to be some kind of mod?
    lol yes it will fit no problem, plug and play, so to say... if you want to keep your door light when you open your door, you need to swap out the circut board on the back, and also your odometer, or you will have like me, i open my door, and my gas light comes on lol
