Thread: Optilux 1200 fog lamps
Showing results 1 to 3 of 3
    hello people. I've had these fog lamps for a looooong time and just haven't had the time to install them. In the directions, it says I can have them either wired to turn on with the low beams or high beams. I want to have them wired to a switch that I can just turn them on or off as I please. Here's the diagram: Diagram I'm not good with relays and wires and whatnot so if anyone could help i'd appreciate it. Thanks.
    Just put a switch in place of the relay between the red power wire and the black wire going to the lights.
    Have it in this order:
    Battery--Fuse--Switch--Lights--Ground
    ______||____||_____||_____||___
    _____Red___Red___Black__Blue__
    Quote Originally Posted by frag_daddy_2007
    wrong. that switch will be taking full load in the above configuration. the reason for having the relay is to isolate the switch from the entire load. actually it's way more simple. just use the stock wiring (which will use the stock relay).
