Check your fluid yet?
You have to check it hot, while the engine is running and in neutral. I found its better let it set for about 10 minutes after driving then start it back up, shift into all the gears ending in neutral. (apply the parking break) check the dipstick and make sure its full and the fluid is a nice clear red color. if it's brown and smells burnt then get it changed.
From what I read these trannys are pretty sensitive and need to be well maintained. Also read that they are one of the better trannys when it comes to smooth shifting and performance.
