I had this same problem. Your motor is probably going out right now. Try not to use your window as much as possible and get it into the shop asap. They may be able to fix something else and save you the cost of having to get a new motor. It is probably too late though. Check out this post. http://www.clubtgc.org/forum/viewtopic.php?t=3883
