Thread: Relocating 8G battery.
Showing results 1 to 20 of 20
    Has anyone here relocated their battery to where the VR4 has it.
    I did a search but only came up with a price for a relocating kit for the trunk.
    Id rather not relocate to the trunk cause I use every inch of it.
    sorry previous link did not work.
    thanks
    8G 4 life!
    Mods: CAI,Grounding wires, CCorners, Shaved, 3G STB. AGX/Teins, Addco bar, OZ F1 wheels And well maintained : )
    i believe mante has done it. on his orignaly usdm 8g.
    i've thought about doing it but thats where my intake filter sits.
    that link is in japanese.
    Jigz-TGCIL Sosick Motorsports
    Quote Originally Posted by 4g63lover
    Link did not work but picture is up.
    Thanks
    8G 4 life!
    Calipso
    The 8G VR4 is so pretty. Quite an interesting spot for the battery. Doesn't leave much if any room for addition in the engine bay. I'd just relocate the battery to the trunk because additional wiring/mods would be hard without any space.
    well, i couldnt see why you cant put it there unless you still have the stock airbox.. my cold air runs straight down after the MAF so theres a blank space where the old airbox used to be. just make a custom bracket to hold it in, extend the terminal wires and you should be good to go.
    if you ant to put it there and have the stock air intake,
    just get the intake system and battery box off a 2g diamante.
    pretty cool, not only is your battery in a more convinient spot, but it also now concealed inside an oem battery box.
    08-06-2005
    Long beach/ guam
    1,585
    yup tried that but didn't have space for the intake.. might need more work than you think..
    New Member
    08-08-2006
    Beaverton/Covallis
    65
    Is that the stock STB for the VR4s? If so, any idea where I could get one?
    * KYB GR-2 shocks and struts $210
    * Progress Technology lowering springs $157
    * Lowering your own car for the first time, priceless.
    Quote Originally Posted by PDT1631
    I think someone was selling one here. They are not cheap.
    Thanks for the diamante Idea Ill look into that at a junk yard.
    The intake box on mine is gone and If I do intall it there Ill figure out what to do with the intake. I guess now the question is how someone does it? Do they buy a universal battery tray or what?
    8G 4 life!
    it won't fit your 8g, so don't bother
    the vr4 has a completey different suspension from yours
    I kind of have my red top battery in that location, but I also have my yellow top in the stock location. I will try and get some pics when I have a sec...
    unless you have a JDM 8g it won't be good for anything but a towel rack.
    Quote Originally Posted by Niytrus
    Thanks.
    8G 4 life!
    Calipso
    Quote Originally Posted by Reelax
    USDM Strut towers different lengths than the JDM 8G?
    Quote Originally Posted by Calipso
    different length and mounting angle. different suspension. different chasis code.
    Quote Originally Posted by SLS2000
    Thanks.
    No problem, will try and snap it later this week if I have a chance...
    11-05-2003
    San Francisco Bay Area
    1,517
    You can kind of see it from these pictures, but Underated used to have his battery behind the left headlight where the stock airbox was, but I think he relocated to the trunk:
    http://www.blacktrax.net/project001newU.html
    Quote Originally Posted by DryBear
    Looks like it might fit without a problem.
    Thanks
    8G 4 life!
    Calipso
    I'm guessing that custom modifying it would probably compromise the whole point of having the strut bar........
