i believe mante has done it. on his orignaly usdm 8g.
i've thought about doing it but thats where my intake filter sits.
Has anyone here relocated their battery to where the VR4 has it.
I did a search but only came up with a price for a relocating kit for the trunk.
Id rather not relocate to the trunk cause I use every inch of it.
sorry previous link did not work.
thanks
8G 4 life!
Mods: CAI,Grounding wires, CCorners, Shaved, 3G STB. AGX/Teins, Addco bar, OZ F1 wheels And well maintained : )
Originally Posted by 4g63lover
Link did not work but picture is up.
Thanks
8G 4 life!
The 8G VR4 is so pretty. Quite an interesting spot for the battery. Doesn't leave much if any room for addition in the engine bay. I'd just relocate the battery to the trunk because additional wiring/mods would be hard without any space.
well, i couldnt see why you cant put it there unless you still have the stock airbox.. my cold air runs straight down after the MAF so theres a blank space where the old airbox used to be. just make a custom bracket to hold it in, extend the terminal wires and you should be good to go.
if you ant to put it there and have the stock air intake,
just get the intake system and battery box off a 2g diamante.
pretty cool, not only is your battery in a more convinient spot, but it also now concealed inside an oem battery box.
yup tried that but didn't have space for the intake.. might need more work than you think..
Is that the stock STB for the VR4s? If so, any idea where I could get one?
* KYB GR-2 shocks and struts $210
* Progress Technology lowering springs $157
* Lowering your own car for the first time, priceless.
I think someone was selling one here. They are not cheap.Originally Posted by PDT1631
Thanks for the diamante Idea Ill look into that at a junk yard.
The intake box on mine is gone and If I do intall it there Ill figure out what to do with the intake. I guess now the question is how someone does it? Do they buy a universal battery tray or what?
8G 4 life!
it won't fit your 8g, so don't botherOriginally Posted by PDT1631
the vr4 has a completey different suspension from yours
Originally Posted by Niytrus
Thanks.
8G 4 life!
USDM Strut towers different lengths than the JDM 8G?Originally Posted by Reelax
You can kind of see it from these pictures, but Underated used to have his battery behind the left headlight where the stock airbox was, but I think he relocated to the trunk:
http://www.blacktrax.net/project001newU.html
Looks like it might fit without a problem.Originally Posted by DryBear
Thanks
8G 4 life!
I'm guessing that custom modifying it would probably compromise the whole point of having the strut bar........Originally Posted by Reelax
