yes it will work i am running a set of 18x7.5 and i am on tein s-tech springs, no rubbing issues at all fit ment is fine 8)
I need a definate answer as to fitment, before i put money into the bigger tires. I'm lowered on Eibach Pro-kit, no camber correction in the rear, so they have a good angle. Will a set of 18x7.5 with 42mm offset, with 225/40/18 tires, fit without rubbing, and without me rolling the rear fender? If anyone is running this setup, please let me know.
2003 Dover White Mitsubishi Galant ES
1997 Tarmac Black Mitsubishi Eclipse GST
Much Respect.
Be Blessed.
Shane
You have 42mm offset?Originally Posted by shaneb
another member has wheels with those same specs. dangerdanj. he's lowered probably lower than yours since he has teins but the only big issue for him i recall was his camber. with "perfect" camber it would rub on the fender, but with slightly negative camber (which is good) he can clear the fender better. i don't see him around alot here lately but if he does find this post, i know he'll chime in.
this is what my galant looks like on my 18x8 et38 its close but with the negative camber it dosent rub at all. even with people in the back. so you should be fine. I'm on Intrax springs too which are a little lower. If I were to go any lower though I would rub on the part of the tire that sticks out right before the lip.
yes 42mm and my g is lower than that as i have tein's 8)
and there are no issues
Much Respect.
Be Blessed.
Shane
i got 18x7 40 offset...lowered on teins
no need for the camber kit for me...no rubbing issues...oh...225/40 for the tires
Thanks for all the replies guys, that was an awesome help. I'll be ordering the 225's as soon as i get my next paycheck.
