the dealer ov course should have ur harness. take a look @ that. look the the size of the wire. then go visit some local auto parts stores. they should have the harness too. pick the one with the thickest wire. the last thing u want is to buy a harness that has wire that is thinner than stock. if you do, you're likely to melt ur harness.
as for replacement, its fairly easy to replace. especially with the oem. look at the harness when u purchase it and you will see fi you will be able to install it yourself. if you are in doubt about it, get it installed by a friend or professionally
