Thread: Help with the Mitah.
Showing results 1 to 5 of 5
    I got everything ready to install a Kenwood.
    I ordered the (Mitah / Wire harness) package but it came with out instructions. I know how to hook up the wire harness but Im a little confussed as to what am I suppose to hook up the blue wire from the mitah to.
    http://www.autotoys.com/x/catalog/MITSUBIS...ESS_p_1379.html
    thanks in advance
    8G 4 life!
    Mods: CAI,Grounding wires, CCorners, Shaved, 3G STB. AGX/Teins, Addco bar, OZ F1 wheels And well maintained : )
    07-31-2002
    Baltimore, MD
    2,848
    Quote Originally Posted by SLS2000
    thanks in advance
    If I'm not mistaken the blue wire goes to a switched (ignition on) 12 volt source. This is so you don't leave the head unit on without the ignition being hot.
    Chip
    (Paint Code: Porsche LC9Z)
    Quote Originally Posted by Fishboy55
    which is pretty much the blue wire coming out of the radio which can be used for a power antenna or aftermarket amplifier???
    ( if this is the case than thats what I thought but Im just trying to make sure so as to not damage the factory amp)
    8G 4 life!
    You're right but for the wrong reason. The blue wire from the mitah is the amp turn on wire. That will get hooked up to the blue/white wire from the kenwood radio.
    MECP First Class Certi-fried installer.
    For the right price, nothing is impossible.
    Quote Originally Posted by cntrylvr79
    Thank you!!!
    close thread and pin it! :laughing: :laughing: :laughing:
    8G 4 life!
