you just need a vavle cover gasket set.Originally Posted by luke9511
its probably a 60 minute affair.
just remove your spark plug wires.
then the inspection cover for te timing belt.
then the few bolts for the valve cover itself.
get the old gasket material out.
get the old orings out.
install the new gasket and orings.
install and torque to spec.
its a simple affair.
skill level: novice
