Thread: injector question
Showing results 1 to 3 of 3
    Are the 4g63 inejctors sidefeed or topfeed
    08-23-2004
    Chaska, Minnesota
    1,370
    i believe side fed, the plugs are right down the center.
    To my knowledge, the only side-fed injectors in a four cylinder application is the ka24 Nissan engine. But than again, I don't randomly look at the design of fuel injectors so....
    Mitsu injectors are all standard top fed design
