Thread: Who still has their origional tranny
Page 8 of 8 FirstFirst ... 45678
Showing results 141 to 152 of 152
  1. #141
    I still have my OEM tranny..
    2003 ES with 128k
    Going to to a tranny fluid change tmr! with OEM Fluids!!!! its the way to go!
  2. #142
    2003 GTZ with 36k original mileage on engine and tranny....so, NO problems at all for sure!!
    P.S. But I have heard that Mitsu has had problems with automatic transmissions' selenoids, specially on 6g, 7g, and 8g V6 cars (because of the torque they produce), 1g diamantes and maybe all eclipses with same trannys. I guess most of the problems then are because of electrical components and not because of bad or poor mechanical workmanship.
    2003 MITSUBISHI GALANT GTZ
  3. #143
    2002 I4 ES. 170k. Original Tranny, Original motor. The transmission slips very slightly going into 3rd gear but you can barely even notice it.
  4. #144
    94 s, 350,00 on it with the 5 speed, input shaft bearing has been making noise for a while now but still shifts smoth.
    1994 Galant S. 90 Percent GS.
  5. #145
    2003 es 140xxx still same tranny
  6. #146
    hhp8008
    137,000 miles original trans, annual fluid changes (once a year) generally shifts smooth in all temperatures.
  7. #147
    Tallahassee, FL (FSU)
    1,324
    2001 i4 with 97k. starting to chirp a bit from 1-2
    -Chris
  8. #148
    218k miles, i4, still runs as smooth as can be. :D
    Cali: Sig 3/28/2011
  9. #149
    GalantEVOII
    01 ES... 180XXX miles on it. No real terminalproblems but an occasional slip every now and then
  10. #150
    05-31-2005
    4,735
    99 v6 ~122k.
  11. #151
    2001 ES, 120K no problems. Had a tranny flush at the dealer around 100K.
  12. #152
    11-29-2009
    Chadds Ford, PA
    2,768
    2000 es, 119,754 idk what is had done to it, feels like it slips from 0-20, but that may be part of my other issues that im addressing
