Should fit. Tires thought I like Nitto Gens or Toyo Proxes
Hey im bout to finnally get my racing harts, since i found an awsome deal for the rims and cant let it go. thier not the black finesh i want, but for the price im paying it shouldnt even matter ill get em poweder coated. My question is 19 X 8.5 inch fit my car? yes i serched only came up with 20 x 8.5 and some say it does some say it doesnt, but nothing for 19. heres the extact info off the guy
19 X 8.5 inch 4/5 x 114.3 +38 offset
WHEELS WILL FIT CARS WITH A P.C.D. OF : 4 X 114.3 OR 5 X 114.3
Another question what is the best tire size i should go with this applaction? i have no clue when it comes to sizeing tires im always lost, so happy my current rims came with tires..Thanks guys i really need to know by tommow
pics of rims:
00 Galant ES Turbo/5-Speed
13 GTR
235/35/19
Fold your fenders. It will fit.
EDIT: Are you dropping the car? If yes, then fold it, if not no need.
fold ur fenders? same thing as rolling your fenders right?
yes im droped right now on GC coilovers
13 GTR
yes fold rolled hahaha same thing... I'm running 235/35/19 on my 19s.Originally Posted by IceDouTGaLanT
Wow GC coilovers??? I think that you'll definately have to roll those fenders.Originally Posted by IceDouTGaLanT
Quick guide to tire sizing, lets start with a 205/55/16 tire. The first number 205 is the width of the tire in millimeters, the second number is the aspect ratio which tells you how tall the sidewall is, with our example the width of the tire is 205 and the aspect ratio is 55 so the sidwall is 55% the width of the tire so the sidewall is 112.75 mm tall. The last number 16 is the rim diameter, which is pretty self explanitory, a tire labeled a 16 will fit a 16" rim. How do you tell which tires will fit where, tirerack has a pretty good spec sheet on all their tires in the different sizes offered, when I go 20 mm wider with a tire, I generally go down 5 % in aspect ratio, so starting with a 205/55/16 tire with an outside diameter of 24.6 inches, I can go to a 225/50/16 tire with an outside diameter of 24.6 inches, and wider yet I'll be going with a 245/45/16 tire with a diameter of 24.4 inches.
www.gooichimotorsports.com
ahh thanks 6G72, your post really helped me out alot
13 GTR
This site is healpful too comparing 2 sets of wheels/tires.
http://www.miata.net/garage/tirecalc.html
if you have a real aggresive drop you will rub like crazy. im running 235/45/19 with a 34 offset.
just dont drop too much or run bigger than 235 and you should be ok.
awesome wheels btw.
Cali: Sig 3/28/2011
ya i got bout 1 1/2 inch clearence of the ground, but i was gona rise it when i put my jdm kit on anyways, so it will work out...Thanks alot guys guess pics of completed car will come around spring haha
13 GTR
38 offset.. wouldn't that stick out a bit?? but good luck
i hope it wont stick out to much, well im getting the JDM fender flares hopefully with them it blend in kind of you know???
13 GTR
i'm rolling on 19x8.5 +48mm 225/35zr19 volks on tein ss-p. i choose that tires size because it is the closest to stock diameter so as not to throw off my speedo... my next set of tires will be 235/35zr19. w/ any drop, you will have to roll the rear fenders, no question; especially if you camber correct the rear. CALI is running a low offset (34mm) to clear his evo brakes but his wheels are 8"wide (1/2" narrower). the extra 1/2" is 1/4" on each side of the rim. since 1"=25.2mm, thats about 6.5mm more rim per side. so your wheels will stick out 2.5mm more than his (34mm - 38mm + 6.5mm). it will be tight but w/ the flares, it should sit perfect.
So who thinks I can fit 275's under my g.
Man I can only imagine how that would stick, I'd probably need either a different steering box or a limiter to keep from rubbing through turns.
Man thats street mod champion territory with the right driver, we know the engines can be pushed to put out 400 hp.
can't wait to see them fender flares man..
