You should get the coolant refill and tested for quality. Also as long as the power steering fluid is clean and the level is good I wouldn't worry about it.
You don't hear or feel anything weird?
I've had the car for 2.5 years now, not once have I had to put power steering fluid in. Its still well at the top of the reservoir, not an ounce more can go in. Is this something you flush and refill, or just refill, because I have never done either.
Also I see my coolant will need some more added soon, is there any kind i should use for winter months especially?
It should only be being used if its leaking.
Ya only if there is a leak will you see the PS fluid dwindle.Originally Posted by seth98esT
Drive It Like You Stole It!
7G Erubini Body Kit for sale
No sounds, the PS fluid is pretty dark though. The coolant im not too worried about, ive added coolant in the past and its at the halfway point, so i figured i'd add more soon.Originally Posted by RedGalant2k1
Anyone have any ideas for flushing the power steering fluid, as mine needs to be changed due to heavy overboiling and almost frying the fluid.
www.gooichimotorsports.com
Disconnect one of the lines, turn the car on, while its pumping out keep filling it up :P
Idk, Ive never done it, Id have to look at the lines.
Thats kinda what I was thinking, but I didnt know if there was anything like a speed bleeder for power steering that would work better.Originally Posted by seth98esT
try that
I need to do this soon too (or maybe take it to the shop). My power steering fluid is very dark now. :(Originally Posted by pinoyesv6
thats so funny i was thinking about that like a couple of weeks ago.....but ima take mine to the shop b/c im getting my timing belt replaced soo they can do it....
ALL fluid is used all the time. Just because the fluid level is ok doesn't mean the fluid is ok. Power steering fluid, brake fluid, antifreeze, differential fluid, etc etc all should be drain and/or flushed and refilled regularly. Dirty power steering fluid can create issues within your power steering system.Originally Posted by seth98esT
Hah I meant the level should only be going down if its leaking. Of course you need to flush it every so often. Any fluid will need to be changed at a certain point. Brake fluid, clutch hydrolic fluid, oil, gear oil, atf, coolant, ect. :)
wanna do this too while at tu casa?Originally Posted by pinoyesv6
if u get the supplies to do your car and mine lolOriginally Posted by 9G
can we borrow the guys stuff and fluids?
ha.
Haha, ah well I figured it should be pointed out anyways.Originally Posted by seth98esT
wow and we gotta torque it too!!!! but really it shouldn't be that difficult.
I'll have to do that.
Shouldnt be.Originally Posted by milo111000
