Thread: Hey Guys New Pics Of Whats Coming Up...Some new pics
Page 11 of 31 FirstFirst ... 78910111213141521 ... LastLast
Showing results 201 to 220 of 607
  1. #201
    Quote Originally Posted by QnzMostWanted
    FROM NY to MIA!
    i miss Miami, I used to live on SW 88 in Kendall, right by the 7-11
    holy crap..i live 5 min from there...close to the walmart...NICE
    Fully Built 4G63
    HKS 272
    ported Dual Ball Bearing FP RED 84mm 25psi w/ external dump
  2. #202
    Quote Originally Posted by whokilledhoughes
    FROM NY to MIA!
    lol walmart wasnt there when i was there lmao, i visited the other day and i was like WOW this place looks totally different
  3. #203
    everytime i open this thread I see excatly how i want my g to look. nice job man
    Back in the Family!!
  4. #204
    well im glad to say im over 50% done with gathering most of the turbo parts..so far ive spent a over $2000 and still have about $1500-$2000 to go...some of the prices for parts are cheap due to i work at an auto parts and get stuff cheaper...so as it looks like this will become a $4500 kit..and notice im using the stock manifold...aftermarket manifolds for the evo's range from 150-800 depending on the brand...i could have done this cheaper but im taking my time and getting the right stuff..i know there are some things im getting that are not necessary to run boost..but better safe than sorry...theres a guy over at club3g that was able to get this kit running under $1500..it depends on the parts you get. once i have gathered everything i will make a tutorial and step by step instruction on how to turbo your G with a Evo 8 or 9 setup...o and there will be lots of pics :twisted: everyone loves pics...i made this list quickly and there might be some stuff i might have left out, i just did everything off the top of my head...for you turbo guys out there if there is anything you think i would need to add to this list let me know :)
    Whokilledhoughes Turbo Kit List
    1. Evo 9 Big 16G with 10.5 Hot side (DONE) $400
    2. Evo 9 Stock Turbo Manifold (DONE)$80
    3. New Turbo Gaskets (DONE)$30
    4. SSSTUDS Extended Manifold Studs and Nuts (DONE)$59
    5. ½ spacer(RRE $30) machined at ¼ top and 3/8 bottom around $40-$80 depends
    6. 2 OEM Exhaust Manifold Gaskets $15 each
    7. Turbo oil Feed line and fittings (almost done) ~$80
    8. Turbo drain line and fittings (almost done) ~70
    9. Turbo Coolant inlet and outlet hoses
    10. Vacuum Manifold $25-$40
    11. Greddy Oil Block Adapter ~$70
    12. Oil Catch can ~$30-$80 most likely ebay brand ~$30
    13. Intercooler (DONE) Ebay $100
    14. Intercooler Piping and couplers with T-bolt clamps $500-750 Hopefully less, but i doubt it.
    15. SSQV Blow Off Valve (DONE) $200
    16. 3” custom down pipe $250-$300
    17. 3” custom cat-back with magnaflow muffler $300-$450
    18. Auto Meter Boost Gauge (DONE) $100
    19. Auto Meter EGT Gauge (DONE) $125
    20. Auto Meter Engine Temp Gauge (DONE) $80
    21. AEM Wideband with O2 sensor (DONE) $295
    22. Auto Meter Volt Meter Gauge (DONE) $80
    23. Auto Meter Oil Pressure Gauge (DONE) $50
    24. 3 Gauge Pod on pillar (DONE) $25
    25. 3 Gauge Pod on Dashboard (DONE) $25
    26. Transmission Oil Cooler (DONE) $55
    27. Aeromotive Fuel Pressure Regulator (DONE) $120
    28. Aeromotive Fuel Pressure Regulator Gauge (DONE)$25
    29. Greddy E-manage Blue $285 ebay
    30. Greddy E-manage Injector Harness $28 ebay
    31. Greddy E-manage Ignition Harness $40 ebay
    32. WRX 440CC Injectors with clips (DONE) $100 used
    33. Fuel Rail Adapter For Fuel Pressure Regulator ~$25
    34. Walbro 255LPH Fuel Pump $90
    35. Vacuum and Heater/transmission Hoses various Sizes ~???
    36. New Fuel Injector O-rings (DONE) $3
    37. NGK Spark Plugs 2 steps colder BKR7E-11 (DONE) $5
    38. AEM Adjustable Cam Gear(red) $160
    39. Timing Belt and Balance Shaft Belt $70
    40. Both Serpentine Belts(dayco) $30
    41. Exhaust heat wrap for A/C lines and Downpipe ~40
    42. Random fitings and other stuff ~50
    Fully Built 4G63
    HKS 272
  5. #205
    Somebody did their homework! :smt045
    Look forward to seeing the process of your G come alive! Damnit I need a motor. :evil:
  6. #206
    Member
    05-16-2007
    LaGrangeville, NY
    201
    The body work looks great and the shopping list seems hot. Good luck with it all. One hell of 8G when you are done.
  7. #207
    04-25-2007
    727
    man your ride is coming together really nice .... Which you all welll with the project.. I I have come so close to finish collecting parts but things change :cry: but anyways can't wait to see that thing boosted....
    Oh yea, are you staying auutomatic?
  8. #208
    well vr4 emblems off...did something better...NICE :)
    hmmmmm..getting close...my idol...my fav. G :)
    Fully Built 4G63
    HKS 272
  9. #209
    11-24-2002
    Originally TGCNY, Now TGCTX
    1,781
    the car looks really good man. Good luck on that turbo set up. :)
    -Pedro
  10. #210
    Looks good, whats with a bootlem mmc emblem?
  11. #211
    had some time in my hands and decided to do a little something to the VC.
    Fully Built 4G63
    HKS 272
  12. #212
    07-19-2007
    Connecticut
    3,994
    wow good job, looks nice
  13. #213
    very very nice ! can´t wait to see the turbo in...
    alex
  14. #214
    well a little update...went to the muffler shop and got a 3" stainless steel cat-back with a 3" magnaflow resonator and a 3"maganaflow muffler with a 4" tip...the car sounds really damm good at start up and acceleration really nice and deep...will post a video later...only downside for now is that i lost my low end completely,due to the N/A motor...and after 3500 RPM the nice deep tone changes and screams like a fartpipe civic...no worry tho as i have been told that when the turbo goes on its going to get rid of the raspiness and make a nice steady tone all around...anyways heres a couple pics from the install..everything came out to $585 which is not that bad..the stainless steel piping is what brought the price up...
    Fully Built 4G63
    HKS 272
  15. #215
    Kansas City, MO
    1,244
    Wow it must be Exhaust Day! Looks really clean man. That car is nice.
  16. #216
    looking good, cant wait to see it the 29th and y is it raspy if u have a resonator and cat???
  17. #217
    Quote Originally Posted by alexvr
    well there is no cat due to i got the DC sports 4-2-1 headers with no cat...but like ive said the 3" piping is too big for the N/A motor so it created that sound...once turbo is on...WHOoooSH!!!... :twisted:
    ask galant305(david)..he's heard it...sounds really nice and deep...and in the top end...it just screams like a monster..~60-~100...i guess its low end that i get the raspy sound and only betweeen ~3000 RPM- ~3700 RPM...Weird stuff...but W/E...My friend calls it the temporary V-Tech as it hit hard and then gears change and goes back to steady tone..
    Fully Built 4G63
    HKS 272
  18. #218
    my dads does the same thing.. it kinda sounsd liek someone is holding a card over the muffler tip lol .... he has 2.5 inch pip eall the way back with a high flow cat and it still does it.. but i can imagine how it sounds with 3 inch must be deep as hell :twisted:
    FOUNDER OF THE EVO WING ON A G GROUP member #1
  19. #219
    SO it begins...what a pain to cut the crash bar...thank god its over...anyways heres step one to the turbo project...will keep you guys informed within the next month or so...
    damm crash bar :evil:
    [/list]
    Fully Built 4G63
    HKS 272
  20. #220
    05-31-2005
    4,735
    cool.
