Thread: Hey Guys New Pics Of Whats Coming Up...Some new pics
Page 13 of 31 FirstFirst ... 39101112131415161723 ... LastLast
Showing results 241 to 260 of 607
  1. #241
    08-15-2006
    Perth Amboy, NJ
    1,558
    Quote Originally Posted by whokilledhoughes
    yep...well the guy said he could have pushed a little more ponies out if the engine was warmer...and having a 3" cat back is no good either...not that much difference maybe 3-5 ponies more...
    would that be from back pressure? i ask cuz i have a 2.5" exhaust and might dyno before i finish my turbo setup as well...
    run1206's Rear Disc Tutorial
  2. #242
    Quote Originally Posted by run1206
    i dont think it makes much of a difference...you just loose low end since there is no back pressure what so ever.... but i know if i didnt have the 3" cat back i would have gotten a little more ponies... i do feel the car way slower than it was before...and gas milage...lets not go there...i do about 225 on a full tank...not stepping on it...since there is no back pressure the left over gas in the engine is lost and not burned...w/e...once on boost everything should be going back to normal...
    Fully Built 4G63
    HKS 272
    ported Dual Ball Bearing FP RED 84mm 25psi w/ external dump
  3. #243
    Lack of power is not because of lack of backpressure, that is a myth. Its because the exhaust pulses are too spread out. With stock exhaust, each exhaust pulse in turn, helps the next pulse pull itself through the piping. The bigger pipe you go without pushing more air through your motor(more mods, turbo, s/c, heavy modded NA), the further apart the exhaust pulese get, and the slower they move through the exhaust.
    Taken from a Honda forum doh:
    Backpressure: The myth and why it's wrong.
    I. Introduction
    One of the most misunderstood concepts in exhaust theory is backpressure. People love to talk about backpressure on message boards with no real understanding of what it is and what it's consequences are. I'm sure many of you have heard or read the phrase "Hondas need backpressure" when discussing exhaust upgrades. That phrase is in fact completely inaccurate and a wholly misguided notion.
    II. Some basic exhaust theory
    Your exhaust system is designed to evacuate gases from the combustion chamber quickly and efficently. Exhaust gases are not produced in a smooth stream; exhaust gases originate in pulses. A 4 cylinder motor will have 4 distinct pulses per complete engine cycle, a 6 cylinder has 6 pules and so on. The more pulses that are produced, the more continuous the exhaust flow. Backpressure can be loosely defined as the resistance to positive flow - in this case, the resistance to positive flow of the exhaust stream.
    III. Backpressure and velocity
    Some people operate under the misguided notion that wider pipes are more effective at clearing the combustion chamber than narrower pipes. It's not hard to see how this misconception is appealing - wider pipes have the capability to flow more than narrower pipes. So if they have the ability to flow more, why isn't "wider is better" a good rule of thumb for exhaust upgrading? In a word - VELOCITY. I'm sure that all of you have at one time used a garden hose w/o a spray nozzle on it. If you let the water just run unrestricted out of the house it flows at a rather slow rate. However, if you take your finger and cover part of the opening, the water will flow out at a much much faster rate.
    The astute exhaust designer knows that you must balance flow capacity with velocity. You want the exhaust gases to exit the chamber and speed along at the highest velocity possible - you want a FAST exhaust stream. If you have two exhaust pulses of equal volume, one in a 2" pipe and one in a 3" pipe, the pulse in the 2" pipe will be traveling considerably FASTER than the pulse in the 3" pipe. While it is true that the narrower the pipe, the higher the velocity of the exiting gases, you want make sure the pipe is wide enough so that there is as little backpressure as possible while maintaining suitable exhaust gas velocity. Backpressure in it's most extreme form can lead to reversion of the exhaust stream - that is to say the exhaust flows backwards, which is not good. The trick is to have a pipe that that is as narrow as possible while having as close to zero backpressure as possible at the RPM range you want your power band to be located at. Exhaust pipe diameters are best suited to a particular RPM range. A smaller pipe diameter will produce higher exhaust velocities at a lower RPM but create unacceptably high amounts of backpressure at high rpm. Thus if your powerband is located 2-3000 RPM you'd want a narrower pipe than if your powerband is located at 8-9000RPM.
    Many engineers try to work around the RPM specific nature of pipe diameters by using setups that are capable of creating a similar effect as a change in pipe diameter on the fly. The most advanced is Ferrari's which consists of two exhaust paths after the header - at low RPM only one path is open to maintain exhaust velocity, but as RPM climbs and exhaust volume increases, the second path is opened to curb backpressure - since there is greater exhaust volume there is no loss in flow velocity. BMW and Nissan use a simpler and less effective method - there is a single exhaust path to the muffler; the muffler has two paths; one path is closed at low RPM but both are open at high RPM.
    IV. So how did this myth come to be?
    I often wonder how the myth "Hondas need backpressure" came to be. Mostly I believe it is a misunderstanding of what is going on with the exhaust stream as pipe diameters change. For instance, someone with a civic decides he's going to uprade his exhaust with a 3" diameter piping. Once it's installed the owner notices that he seems to have lost a good bit of power throughout the powerband. He makes the connections in the following manner: "My wider exhaust eliminated all backpressure but I lost power, therefore the motor must need some backpressure in order to make power." What he did not realize is that he killed off all his flow velocity by using such a ridiculously wide pipe. It would have been possible for him to achieve close to zero backpressure with a much narrower pipe - in that way he would not have lost all his flow velocity.
    V. So why is exhaust velocity so important?
    The faster an exhaust pulse moves, the better it can scavenge out all of the spent gasses during valve overlap. The guiding principles of exhaust pulse scavenging are a bit beyond the scope of this doc but the general idea is a fast moving pulse creates a low pressure area behind it. This low pressure area acts as a vacuum and draws along the air behind it. A similar example would be a vehicle traveling at a high rate of speed on a dusty road. There is a low pressure area immediately behind the moving vehicle - dust particles get sucked into this low pressure area causing it to collect on the back of the vehicle. This effect is most noticeable on vans and hatchbacks which tend to create large trailing low pressure areas - giving rise to the numerous "wash me please" messages written in the thickly collected dust on the rear door(s).
    VI. Conclusion.
    SO it turns out that Hondas don't need backpressure, they need as high a flow velocity as possible with as little backpressure as possible.
  4. #244
    01-07-2006
    707
    Check your PM's Paul
  5. #245
    Quote Originally Posted by DNSerrano
    thanks man...Sig is awsome.. :twisted:
    Fully Built 4G63
    HKS 272
  6. #246
    08-08-2004
    Las Vegas
    2,099
    damn that sig is of the hook
  7. #247
    02-28-2005
    Metropolis
    3,540
    Quote Originally Posted by underated
    That is a sweet sig.
  8. #248
    nice!!! yea u would of deff had more power if u had a smaller piping...but i think that even with the piping being 3". with the headers u should of gained more power...davids is 155 stock not 145 so maybe thats y its more...HP is confusin lol
  9. #249
    TGC Regular djflex167's Avatar
    07-21-2007
    Manhattan, New York
    709
    Nice!!
    Keep Up The Good Work Man!!
  10. #250
    got a little bored...and the turbo project is 98% completed in the parts gathering section...by january i should begin with her...i was bored today and decided to paint the rims i got...sorry its a low quality pic taken by a cell phone...ill take better pics later...anyways i think it came out preatty good...
    Fully Built 4G63
    HKS 272
  11. #251
    Experienced TGC Member Divinity's Avatar
    05-01-2007
    Jacksonville, FL
    1,281
    Nice choice of color!
    ~Lady Driven~
  12. #252
    08-08-2004
    Las Vegas
    2,099
    yah that looks sweet, lets see some clearer pics when you get a chance... oh and im looking forwards to seeing the results of the turbo install
  13. #253
    08-04-2003
    NY
    4,344
    Its looking good man.
    I have the same bumper with almost the same size FMIC, except mine is 3" thick and sits against the bumper tight. You shouldnt have to really cut the bumper that much on the passenger side, I just had to trim about 1/4 off the inside edge of the foglight opening, because thats right where the pipe bends around. What size piping do you plan on using? I run 2.5"
    99' Galant ES
    4G64/63T
    AEM EMS
  14. #254
    05-03-2007
    Socal/Central Coast
    3,803
    wow I never realized how good white cars look with gold rims.
    Nice it's lookin good. Keep up the good work
  15. #255
    wow those pics look great!
    uhhhh...... Whats a 9g???
  16. #256
    Quote Originally Posted by Stewi
    i plan on using the same 2.5"... :)
    Fully Built 4G63
    HKS 272
  17. #257
    05-31-2005
    4,735
    Nice!
  18. #258
    04-10-2005
    NYC
    3,695
    looks good man wonering where u been....good choice on the gold wheels came out good
  19. #259
    Niiiiice!!! I really like the rims painted a lot better.
    Lo§'s 99 GTZ
  20. #260
    damn the painted rims really will set it off. your car is beautiful
    2011 Camry- 202 miles- just picked up 9/10/10
    2008 Pontiac G6- 26,065 miles- traded in
    1999 Galant ES- 91,846 miles- long gone
