Thread: Poor Gas Mileage...
Showing results 1 to 4 of 4
    Poor Gas Mileage...
    well I have my car running great and the problem turned out to be clogged fuel injectors and alot of crud in the tank.
    I filled up, drove around for 100 miles and filled it back up to get my mileage and it took 6 gallons of gas, thats 16.6 MPG, not good at all.
    I am getting my "check engine light" every once in a while but it never stays on for more than a few seconds.
    My O2 sensor is new so I know thats not the problem.
    Any idea where to start? Coolant temp sensor maybe?
    If there isn't a Z or an X in the cars name I don't want it!
    1983 Datsun 280ZX
    1978 Datsun 280Z Turbo
    1990 Mitsubishi Galant GS-X
    Re: Poor Gas Mileage...
    Quote Originally Posted by MaineGSX
    simple. how about all the recomended maintenance for the car. did u do all that?
    Yeah, new plugs, wires, filter, pcv, fuel pump, fuel filter, cleaned gas tank, O2 sensor, clenaed injectors, changed oil, coolant system flush....
    1983 Datsun 280ZX
    07-20-2003
    Orlando, FL
    3,169
    Could be possibly EGR related. You could replace the EGR valve..or just eliminate with a $14 blockoff plate. It could be a failing MAF sensor..but I haven't had one go bad on me or known anyone that has to be the cause of it. I am assuming it because the MAF sends signals to the ECU to help determine air/fuel mixture.
