Thread: Engine dies above 3K
Showing results 1 to 4 of 4
    NEWBIE
    01-22-2007
    Riverton, Perth, Western Austrlia
    2
    Hi all,
    I have a HH SOHC Galant, manual.
    I have a problem, when I start it seems to be missing but will drive ok at first ( just drives like a pig) but after a while usually above 3000 rpm will die even with full throttle if i baby it will drive but has near no power any ideas at all
    Any help appreciated.
    John
    NEWBIE
    01-22-2007
    2
    Had another look today and found this in the cap :(
    Anyone ever had this happen, think I might just part out the car :evil:
    08-06-2005
    Long beach/ guam
    1,585
    sorry to hear that.. but the best move is to get a newer G.. good luck..
    07-20-2003
    Orlando, FL
    3,169
    Wow..never seen that before :shock: Well its safe to see that its ignition related...you are probably not getting a solid spark to the plugs results why the car dies at 3000 grand and above.
    Is there any play in the distributor shaft where the rotor is suppose to connect to? If thats the problem...just buy a new distributor, its safe to say thats your problem. Looks like its moving resulting to the rotor rubbing againsts the top part of the cap.
