Thread: To make a 2.5L
Showing results 1 to 4 of 4
    TurboGalant
    To make a 2.5L
    How much will have to be bored out and what size pistons will I have to buy to make the 4g64 a 2.5L engine?
    94es24
    you will need a bore of about 89mm
    hyer717
    Hmmm, might want to check and see how much cylinder wall you would have left, might be getting a little thin...??? Could cause overheating problems if your walls are too thin. Just my $.02
    fstrthnu
    You can only safely bore out the '64 0.020 over. I don't know how much extra displacement that would give you though.
