Thread: Brake question. Mine were squeeling the other day.
Showing results 1 to 4 of 4
    Tazz2000
    Are Raybestos brakes any good?
    And do we have Semi-Metalic? or Ceramic? *edit* Found out we use Semi-Metalic
    Which should I get?
    :ironchief3:
    Baltimore, MD
    2,848
    Yes, Raybestos brakes are good bargain brakes. If you want less brake dust go with semi-metallic. The more metallic, the less dust, but the more chance of squeel. To reduce the squeel, get some brake quiet gel and apply it before you replace the pads.
    Chip
    Chip
    (Paint Code: Porsche LC9Z)
    Tazz2000
    You think they would apply it when they installed them? I can go pick it up in the morning.
    <div class='quotetop'>QUOTE(Fishboy55)</div><div class='quotemain'> If you want less brake dust go with semi-metallic. The more metallic, the less dust, but the more chance of squeel. Â*
    Chip</div>
    I thought that if you where to go with ceramic there is less brake dust.
    Jason
    www.edelhausrottweilers.com
