Thread: Sideskirts?
Showing results 1 to 4 of 4
    Lazy
    Sideskirts?
    Does any one know what other sideskirts i can use, like custom make it to fit? ¿(Accord,Eclipse)?
    95G-Hustler
    accord 94-98, camry 96-??, well thats all i know about
    San Antonio, Tex-Mex
    1,413
    Pretty much the rule of thumb is that you can use any sideskirts you want just as long as they are not tooo short, too long is OK.
    It is easier to shorten them (hacksaw) then to make them longer...
    I would recommend ANY full sized sedan. Just call ahead for measurements.
    <-Check it out Maz
    My 7g
    Why wouldn't 2g eclipse/talons work?
    Since we have the same frame and all, I don't see why they wouldn't have the same length. The only things is that they have that little pocket in the rear behind their doors, but it still might work.
