Thread: Galant E33 Question
Showing results 1 to 4 of 4
    we88uc
    Galant E33 Question
    Hello,
    i have a question for the electronic failure-check.
    My Daytona has an electronic check for failures with the start-key. Does the Galant this too ??
    Thanks for your answer.
    bongi
    you can use a voltmeter to check ecu codes but need to have the service manual to know what it stands for. 8)
    we88uc
    Thank you for answering - or in German : Herzlichen Dank
    bongi
    what do you mean by krawalbud?
